Kaal frame beschermen tegen roest.
four_stroker
Bericht door four_stroker »
Ik wil mijn frame misschien helemaal kaal maken en dan onbewerkt laten. Hoe zorg ik dan dat het niet gaat roesten? In blanke lak zit ook vocht toch?
Mano
Krasser
Bezit: CD50
Re: Kaal frame beschermen tegen roest.
Bericht door Mano »
Bedoel je misschien dat je het er uit wil laten zien alsof het onbewerkt is?
Want als je het echt kaal laat gaat het gegarandeerd roesten.
four_stroker
Onbewerkt, maar wel bewerkt tegen roest ;)
Mano
Krasser
Bezit: CD50
Bericht door Mano »
FF gezocht en wat gevonden : Penetrol
Question What is a good clear steel coating?
I welded together some mild steel frames for a friend of mine, and am wondering what are some good ideas to clear coat the steel with? I have used a product supposedly for use on steel if inside (ZIM), but it is water based and creates small rust "blooms" just by being applied. I've used cheap spray on clear coats, but they seem to only help so much. I can't afford fancy and expensive powder coats, and I am looking for something fairly accessible and direct.
Any ideas?
Alison
View Public Profile
Find all posts by Alison
#2
Old 04-10-2004, 05:40 PM
Araich's Avatar
Araich Araich is offline
Moderator
Re: What is a good clear steel coating?
Hi Alison, try a product called Penetrol. It is a clear oil based paint additive that has extremely high penetrating qualitites - pushing out the air and moisture from the pores in the steel which seed rust. You'll need to give the work several coats, the more the merrier, and ultimately rust will find a way under... Just the same as powder coating.
That said, in my experience it is the best coating of them all, and it is cheap.
If it is a complex shape, with hidden seams and pockets, I recommend using a diluted mixture (with turps) and drowning the work as the first coat.
Also, cleaning off the work first with thinners or meths seems to help.
You can buy the stuff (or similar) at any-old hardware store. Best of luck.
Mano
Krasser
Bezit: CD50
Bericht door Mano »
Bericht door ciebie »
ik zou voor blanke lak kiezen, of het goed hecht op blank metaal durf ik zo niet te zeggen maar ga er wel vanuit eigenlijk.. en voor de oldschool look kan je het natuurlijk ook laten aanroesten 8-) en daarna bewerken..
Ja, het plaatwerk is al zo dik...
cd50-h
Bezit: zero
Bericht door cd50-h »
lijnolie! daar smeren ze die ratrods ook mee in.
Come ride with us
four_stroker
cd50-h schreef:lijnolie! daar smeren ze die ratrods ook mee in.
En is dat eenmalig, of moet je dat elke keer als je gereden hebt weer opnieuw aanbrengen? Blanke lak lijkt mij het meest relaxed, weet alleen niet of het frame onder de lak dan gaat roesten doordat er misschien water in de lak zit..
Bangbrosbode
Bezit: CD50 + PC50
Bericht door Bangbrosbode »
Als er geen zuurstof bij kan komen, kan het volgensmij al helemaal niet gaan roesten... Maar dat weet ik niet zeker :wink:
Bangbrosbode schreef:Als er geen zuurstof bij kan komen, kan het volgensmij al helemaal niet gaan roesten... Maar dat weet ik niet zeker :wink:
Klopt als een bus. Daarom verf/coat je ijzer en staal, om de zuurstof bij het metaal weg te houden.
Mano
Krasser
Bezit: CD50
Bericht door Mano »
Ja dat dacht ik ook
Maar als ik m'n cd-tje zo bekijk na de pekel "attack" van vorige maand begin ik te twijfelen aan de luchtdichtheid van de roestwerende grondverf en meerdere lagen autolak :cry:
Dus veel succes met het Blanke Metaal Look project
Haakie
Bericht door Haakie »
Gouden tip: Owatrol. Dat is doorzichtig en beschermt ontzettend goed tegen roest.
Buick Centurion 7.5L
Honda CB 50J
Mano schreef:Ja dat dacht ik ook
grondverf/primer is niet waterdicht, daarvoor moet er eerst een afwerklaag overheen... (staat als het goed is op pot of bus.)
Mano
Krasser
Bezit: CD50
Bericht door Mano »
Die waterdichte laag dacht ik met meerdere lagen lak gemaakt te hebben...
Nou ja heb ik weer wat te doen als het weer mooi weer is
