New to forum
markking
Bezit: SS50e, SS50zk1-e
New to forum
Bericht door markking »
Hi all, firstly, apologies for not being able to converse in Dutch, I'm Mark from the UK and I stumbled across this site whilst looking for images of SS50's.
I currently have two SS50's, a zk1-e which I finished restoring two years ago, and an SS50e, which is under restoration. It will be finished in the spring.
Here is the zk1-e, first picture with the 72cc motor fitted, second picture with its 85cc motor, 3rd & 4th pics showing it currently sporting a Lifan 110 top end.
markking
Re: New to forum
Here's the SS50e, work in progress.....
skodas
Re: New to forum
Bericht door skodas »
Beautiful bikes! Respect.
markking
Re: New to forum
Thanks skodas, I will update with progress. This is a good site - I didn't realise there was as much interest in the little Hondas in Holland.
Re: New to forum
Hi, welcome! Most Dutch speak, write and understand English quite well, so the language isn't an issue. Just post about your Honda's and keep June 16th free in your agenda. Your UK friends are of course also welcome to post.
koen 50
Bezit: een stoel
Re: New to forum
Bericht door koen 50 »
beautiful bikes, especially the k1! 8-)
jeuj!
Bezit: Honda ST50-G
Honda CB77 Superhawk
Re: New to forum
Bericht door Kippenverver »
Holy ****, those look very nice! Do they ride as well as they look?
markking
Re: New to forum
Thanks all, this is how the zk1-e started out..
I purchased this bike 20 years ago and stored it. Two years ago I thought I'd better do something with it while parts were still available. A lot of the parts supply has since dried up!
Re: New to forum
Is it a motorcycle instead of a moped?
markking
Re: New to forum
Kippenverver schreef:Holy ****, those look very nice! Do they ride as well as they look?
I only rode the 'e' once, back in October when I purchased it. It wasn't very good as the carburetter had a blockage. I just wanted to check what worked and what didn't before I dismantled it.
The zk1-e is sweet, the 110 motor has a lot of torque but maximum revs are only around 7500 due to the small valves and soft camshaft of the Lifan cylinder head. It will still do 100+km/h on the level road, but I'm working on an engine combination that will let me use a 6v 70 cylinder head and a domed piston. This will hopefully let the engine rev more freely as the valves are larger and I can use the S65 camshaft.
markking
Re: New to forum
NIX schreef:Is it a motorcycle instead of a moped?
The 'e' is a motorcycle, the zk1-e is a moped - you can ride this at 16 in the UK.
Mano
Krasser
Bezit: CD50
Re: New to forum
Bericht door Mano »
Welcome Mark,
Good looking Machines indeed!
Are parts easy to find in the UK ? (if so,some of us on the other side of the channel would welcome a good contact to get us to those parts/ better yet to get those parts to us 8-) )
markking
Re: New to forum
What parts in particular Mano?
I use mainly Dave Silver. What is not widely known is that they share a database with other UK suppliers of old Honda parts.
With the 'e' restoration I found a lot of parts are common with the CD50/70, and what Dave Silver are unable to supply I've obtained from Vietnam & Thailand via ebay.
You are all probably familiar with the Dave Silver part number search engine, but here's a link..
http://www.davidsilverspares.co.uk/part ... rt-number/
I use CMSNL to obtain the part numbers and have also used them for parts (and Leertouwer, and Singa, and Rovaza), but avoid it if possible due to the high postage charges from Holland.
Chinese pit bike parts are in abundance in the UK, and are a valuable source of engine spares. You just have to know what is compatible with the Honda engine. For example the twin plate clutch from these engines are much stronger than the single plate Honda item and bolt straight in, though you do need the correct primary gear (67T), and adjust the final drive gearing to suit.
Also, a lot of the pit bike transmission gears fit onto the Honda shafts and offer a choice of ratios, the gears are also wider, and therefore stronger, than the Honda originals - I use pit bike 2nd, 3rd & 4th gears in the 110 motor, with the twin plate clutch, and a high flow oil pump - also Chinese.
I've not had any issues with quality or reliability of any of these parts so far.
I have several spare Honda, and Chinese engines, and spend a lot of time seeing what fits and works between the two.
Mano
Krasser
Bezit: CD50
Re: New to forum
Bericht door Mano »
Well,
I for one am looking for a side cover for my CD50 (left side), and also a headlight like the one you have on your ss50e
complete with speedometer.
Mind you, as cheap as possible off course (He-he, I am Dutch after all :mrgreen: )
markking
Re: New to forum
I'll keep an eye open Mano. We also have regular bike jumbles in the UK, do you have these in Holland? - I have had some really got finds at some of these.
Those parts you mention, I have seen those recently on ebay uk, they sold fairly inexpensively! I didn't buy them because I didn't need them.
