Wire connection.
Jotr
Wire connection.
Bericht door Jotr »
he.
I need some help from you friends.
I have switched to a new wiring network
how do i get connected to the right wires.
engine.
4 pins
White
Yellow red
Black
White red
single Green red
single Black red
new wiring network.
6 pins
Black and white
Red white
Red yellow
White
Green white
Yellow
hope there is a wise man who can help me. :
lil
Bezit: teveel
Re: Wire connection.
Bericht door lil »
what brand is this engine?
also you can check viewtopic.php?f=57&t=55
lil schreef: ↑24 mar 2021 21:38 what brand is this engine?
Looks like a skyteam (numbers in carter.)
Are you sure that 4-pin connector has a yellow/red and not just a yellow?
The loose black/red = cdi power = the red/yellow on the 6-pin plug.
Jotr
Bericht door Jotr »
Hello.
it's a skyteam engine that i bought used. it has only driven about 50 km.
so it is like new.
and yes there is a yellow red cable from the motor.
Jotr.
lil
Bezit: teveel
Bericht door lil »
the lightgreen/red is the neutral sensor, and white is probably for charging the battery. can't be sure for the other wires, you could remove the cover on the left engine side for a little more insight on where the wires lead to and their colors. at least the cdi pulse wire should be easy to spot, the pulse sensor is located near the outer rim of the flywheel
Jotr
Bericht door Jotr »
thanks for the help.
there is life in it now. 👍👍👍
lil
Bezit: teveel
Bericht door lil »
what did you do? plz let us know, so we can learn from it, your experience is valuable.
Jotr
Bericht door Jotr »
Hello.
I solved the problem by opening in to the ignition coil and saw what wires it was to the coil and what kind of one went to the magnet which gives impulse to the ignition coil to the spark plug.
lil
Bezit: teveel
Bericht door lil »
good, what color wire goes where?
Jotr
Bericht door Jotr »
it is
white to white
yellow red to yellow
black to black white
white red to white red
green red to green white black red to red yellow.
then it works incl gear indicator.
