Z50JZ Honda Nice - Takegawa 154cc
10" G-Craft Wheels Alloy (2.75")
Metzeler ME 7 Teen 120/70-10 (front)
Metzeler ME 7 Teen 130/70-10 (rear)
Honda Nice 154cc TJR (see engine specs below)
Keihin 28PE / Stainless Steel Inlet Manifold (custom)
K+N Airfilter
Takegawa Front Sprocket
MAB Stainless Steel Exhaust (custom)
Takegawa Alloy Oil Cooler (custom)
Stainless Steel Oil Lines (custom)
Regina Gold Professional Drive Chain
Daytona Low Seat
Takegawa Short Alloy Rack
Kellermann Micro Indicators (front / rear)
Trelock Digital Speedo
Takegawa Front Brake Controls (black) / Alloy Lever
Takegawa Clutch Controls (black) / Alloy Lever
Takegawa Switchblock (black)
Takegawa HD Clutch Cable 910mm (black)
Daytona Quick Throttle (black)
Handlebar Alloy Screws (custom)
G-Craft Alloy Handlebar (foldable)
Shift-Up Headlight Brackets
Honda NSR 30mm Forks (shortened / modified)
G-Craft Alloy Tripple Clamps
Tapered Steering Head Bearings
Takegawa Fork Pre-Load Adjusters
Takegawa Steering Damper
G-Craft Fork Brace
G-Craft Alloy Fender (front)
G-Craft Alloy Headlight Brackets
G-Craft Brake Caliper Alloy Bracket (front)
Brembo 4-pot Caliper (front)
Braking Wave Brake Disk (front)
BBR Foot Brake Lever
Alloy Master Brake Pump Bracket (custom)
G-Craft Alloy Brake Fluid Reservoir (rear)
Honda NSR Brake Pump (rear)
G-Craft Brake Caliper Bracket (rear)
Brembo 2-pot Brake Caliper (rear)
Braking Wave Brake Disc (rear)
Stainless Steel Brake Lines (front / rear)
G-Craft Triple Square Alloy Swingarm +40mm (custom)
Öhlins Rear Shocks (fully adjustable)
Big Cedar Rear Alloy Fender (black anodized)
G-Craft Alloy Gear Lever (adjustable)
CF-Posh Alloy Rear Sprocket
Kickstand Stainless Steel (custom)
Fastway Performance Footrests
G-Craft Alloy Sidecovers (black anodized)
Takegawa Oil Catch Can (polished / clear anodized)
CF-Posh Battery Eliminator
Honda Nice 154cc by TJR Motorports Germany
*Takegawa cylinderhead Superhead + R (valves: IV 30 - OV24)
*Takegawa camshaft S35D
*TJR crankshaft with 58mm stroke
*TJR special piston 58mm
*Takegawa hydraulic dry-clutch (5 speed gearbox)
*TJR ignition lightened
*TJR special head gasket 58mm
*TJR special cylinder with a new cylinder sleeve 58mm
*Crankcase spindled for cylinder 58mm
