Wire connection.
Geplaatst: 24 mar 2021 19:57
door Jotr
he.
I need some help from you friends.
I have switched to a new wiring network
how do i get connected to the right wires.
engine.
4 pins
White
Yellow red
Black
White red
single Green red
single Black red
new wiring network.
6 pins
Black and white
Red white
Red yellow
White
Green white
Yellow
hope there is a wise man who can help me. :
Re: Wire connection.
Geplaatst: 24 mar 2021 21:38
door lil
what brand is this engine?
also you can check viewtopic.php?f=57&t=55
Geplaatst: 25 mar 2021 00:00
lil schreef: ↑24 mar 2021 21:38 what brand is this engine?
Looks like a skyteam (numbers in carter.)
Are you sure that 4-pin connector has a yellow/red and not just a yellow?
The loose black/red = cdi power = the red/yellow on the 6-pin plug.
Geplaatst: 25 mar 2021 05:58
door Jotr
Hello.
it's a skyteam engine that i bought used. it has only driven about 50 km.
so it is like new.
and yes there is a yellow red cable from the motor.
Jotr.
Geplaatst: 25 mar 2021 11:28
door lil
the lightgreen/red is the neutral sensor, and white is probably for charging the battery. can't be sure for the other wires, you could remove the cover on the left engine side for a little more insight on where the wires lead to and their colors. at least the cdi pulse wire should be easy to spot, the pulse sensor is located near the outer rim of the flywheel
Geplaatst: 27 mar 2021 19:41
door Jotr
thanks for the help.
there is life in it now. 👍👍👍
Geplaatst: 27 mar 2021 20:14
door lil
what did you do? plz let us know, so we can learn from it, your experience is valuable.
Geplaatst: 05 apr 2021 14:31
door Jotr
Hello.
I solved the problem by opening in to the ignition coil and saw what wires it was to the coil and what kind of one went to the magnet which gives impulse to the ignition coil to the spark plug.
Geplaatst: 05 apr 2021 14:38
door lil
good, what color wire goes where?
Geplaatst: 06 apr 2021 18:28
door Jotr
it is
white to white
yellow red to yellow
black to black white
white red to white red
green red to green white black red to red yellow.
then it works incl gear indicator.
