Pagina 2 van 2
Re: Onoplosbaar koppelingsprobleem op een Z50M
Geplaatst: 17 okt 2024 08:18
door MrSinga
gerbrandicus schreef: ↑16 okt 2024 23:14 I wouldn't just swap out the entire clutch. There's a problem, you're a man, you solve problems!
In stead of going around the problem.
What happened when you adjusted the screw? And can you adjust it so that the clutch slips when you kickstart?
opening/closing again opening/closing is after a while not that funny anymore.
And then you use that clutch in an other engine and it works perfect :?
I know it's slightly different then the clutch on any other models (with the clips etc). So it's a bit harder to compaire to a normal clutch. But plates, rolls,... aren't different for these models? fe in a Takegawa 3 plate manual clutch the plates are different in thickness then those from Honda (they place 3 thinner plates in a 2 plate clutch)
Geplaatst: 27 nov 2024 19:46
door Honda 60-70's
Sorry for all this time without news, I thought about this problem and I made this support for the clutch control and see what happens when I press the selector.
Apparently it works, the selector disengages correctly ?
